1993 mitsubishi diamante, alarm/keyless
Rqaasim
Posted: August 23, 2007 at 10:53 AM / IP Logged
I am having a hard time locating the proper wires to use for the lock and unlock on a 1993 mitsubishi diamante i am installing a no name car alarm keyless entry but looking for info on wire location and colors the diagram i got here has some incorrect info hopfully someone has ran across this and can help
Don't think you know it all someone always knows more
peterubers
Silver - Posts: 706
Posted: August 23, 2007 at 7:00 PM / IP Logged
 12 VOLT CONSTANT  RED (+)   IGNITION SWITCH HARNESS
 STARTER BLACK / YELLOW (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
 IGNITION 2 N/A
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 BLUE/BLACK (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 N/A
 KEYSENSE N/A
 PARKING LIGHTS ( - ) N/A
 PARKING LIGHTS ( + ) GREEN / WHITE with SILVER Dots (+)  @ DIMMER SWITCH or DRIVERS KICK PANEL
 POWER LOCK RED / BLUE (1 of 2 Wires) (TYPE B)  @ FUSEBOX, BOTTOM of T SHAPED HARNESS See NOTE *1
 POWER UNLOCK RED / BLUE (1 of 2 Wires) (TYPE B)  @ FUSEBOX, BOTTOM of T SHAPED HARNESS See NOTE *1
 LOCK MOTOR WIRE N/A
 DOOR TRIGGER RED / GREEN (-)  DRIVERS SIDE RUNNING BOARD See NOTE *2
 DOMELIGHT SUPERVISION USE DOOR TRIGGER, Requires Part #775 Relay
 TRUNK RELEASE GREEN/ RED (+), Requires Part #775 Relay  @ TRUNK RELEASE SWITCH
 SLIDING POWER DOOR N/A
 HORN GREEN/ RED to GREEN (-)  @ STEERING COLUMN HARNESS
 TACH WHITE/ BLUE or WHITE  @ COIL PACK
 WAIT TO START LIGHT N/A
 BRAKE GREEN with SILVER Dots (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  BROWN / RED with SILVER Dots (-)  IN PASSENGER KICK PANEL
 ANTI-THEFT N/A
NOTES
 NOTE *1 WIRES CAN BE FOUND IN EITHER SIDE OF VEHICLE OR IN THE HARNESS BEHIND THE GLOVE BOX.MUST TEST WITH PASSENGER SIDE SWITCH.
NOTE *2 A LARGE HARNESS GOES INTO THE RUNNING BOARD FROM THE DRIVER SIDE KICK PANEL.IT IS COVERED IN TAPE.THE RED / GREEN WIRE MAY CHANGE TO A GREEN /WHITE OR A YELLOW/WHITE ON ITS WAY TO THE "DOOR AJAR" LIGHT IN DASH.
The search function is your friend.
