using door lock act for trunk release?
xtearitupx
Member - Posts: 6
Posted: August 23, 2007 at 11:55 AM / IP Logged
With the proper relay and wiring , do you think it'll be possible for me to use a DEI door lock actuator to unhatch the trunk on a 94 civic? As far as physical restraints go, I realize it won't pop it up, I  just need an unlock.
peterubers
Silver - Posts: 706
Posted: August 23, 2007 at 6:36 PM / IP Logged
Possibly, i think the actuator would generate enough force to pop the level.
A cheapie solenoid trunk popper kit is only like $12.00 plus shipping on ebay .. i just did one for a NIssan Maxima '97, works great after one year!
The search function is your friend.
KarTuneMan
Platinum - Posts: 7,056
Posted: August 23, 2007 at 7:36 PM / IP Logged
The typical door lock actuator only rips 6, or 7 lbs. of pull.It " might" work.....but like ubers said. how long will it serve you?
