dodge charger sentry key
profuse007
Gold - Posts: 2,015
Posted: September 16, 2007 at 11:29 AM / IP Logged
make-dodge
model-charger
yr-07
objective- in effort to prove that the GRAY key does NOT work w/ magnum and charger. So I need some confirmation that this key do NOT work for the customer's charger.
my pics below is the key the customer brought in. I told the customer right-off that its not the key bc someone went through this problem awhile back w/ the magnum or so on this forum. I told him to exchange it for the tan one,the latest sentry key for dodge(05+), but the SELLER insisted that it works. I gave him the benefit of a doubt and tested/program again for the second time and still NO GO.
My pictures: note the programming paper says 98+. thats enough evident to say that it does NOT work.
dodge charger sentry key -- posted image.
Houston,TX
tragik
Copper - Posts: 169
Posted: September 17, 2007 at 4:19 PM / IP Logged
Not gonna work. The tan one, like the one for the 2 door sebrings, will work tho.
Northstart.....or start it your damn self.
Chris Luongo
Platinum - Posts: 3,746
Posted: September 17, 2007 at 11:52 PM / IP Logged
That's definitely the correct key. 692352.
That's the exact key we use for all the new-style Chrysers, including:
04-up Durango
05-up Grand Cherokee
300, Magnum, Charger
The letter S on the blade indicates it's the newer style Sentry Key.
KarTuneMan
Platinum - Posts: 7,056
Posted: September 18, 2007 at 12:00 AM / IP Logged
Welll.... seems we have a conflict on the info here.... can't wait to see how this one turns out.dodge charger sentry key -- posted image.
rudydapimp
Copper - Posts: 390
Posted: September 18, 2007 at 6:00 AM / IP Logged
from what I can tell, looks like the tan is what you need.
http://howardkeys.com/pdf/AutomotiveKeys/Chrysler.pdf
profuse007
Gold - Posts: 2,015
Posted: September 18, 2007 at 8:18 AM / IP Logged
are you sure about this?
have you actually tried to use it on the magnum or charger?
The programming instruction came w/ the key was that i followed and I confirmed it w/ bypasskit keyless bypass module's instruction....
hwo did you program yours?
i believe the part number for tan and gray is the same as someone mention about this problem awhile back. I cant seem to find that thread again.
04-up Durango
Houston,TX
profuse007
Gold - Posts: 2,015
Posted: September 18, 2007 at 8:44 AM / IP Logged
I just talked to strattec CS and they said that I need the tan/light brown one.
The CS said that there might be a confusion w/ the part number bc the other sentry key is gray head w/ strattec part #692325 and it covers a lot of OE part#.
Below is the link to the catalog. Although the key marked "s" like in the catalog, it still doesnt convince me.
pdf of strattec catalog
Houston,TX
extreme1
Silver - Posts: 1,070
Posted: September 18, 2007 at 2:41 PM / IP Logged
according to the catalog, you have the right part# fort he gen2 key, the gen1 key is model # 692354
Shaughn Murley
Visions Electronics
Red Deer, Alberta
profuse007
Gold - Posts: 2,015
Posted: September 18, 2007 at 3:47 PM / IP Logged
69354 is not even the transponder nor it is the right groove.
692325 84-groove - this key covers a whole bunch of Chrysler/Dodge/Jeep's vehicles thats from 98-04.
692352 84-groove - this key covers only several cars, and I suspect it only covers the newer chrysler and dodge from 05+.
Houston,TX
profuse007
Gold - Posts: 2,015
Posted: September 20, 2007 at 10:05 PM / IP Logged
chris?
Houston,TX
Monday, March 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
