2007 audi a4
slicksam
Copper - Posts: 291
Posted: October 27, 2007 at 10:56 AM / IP Logged
Anyone have wiring info on the 2007 AUDI A4?
Would like to know how much to charge?
Testing is the key
Posted: October 27, 2007 at 5:31 PM / IP Logged
Use a can1 from DEI or similar it's much easier.
Platinum - Posts: 12,488
Posted: October 28, 2007 at 2:09 PM / IP Logged
Charge alot 2007 audi a4 -- posted image. Will most likely take 3 times longer than it would take to install the same system into a Chevy or Ford. Charge accordingly as we do. These vehicle we charge upwards of $ 600 + to install a remote starter into. You will need a universal bypass module and also a interface module for the doors, tach, triggers, trunk & whatnot.
slicksam
Copper - Posts: 291
Posted: October 28, 2007 at 3:16 PM / IP Logged
I know I need the cansl2 for the doorlocks and tach and also an autotrans for the key + the starter and my labour
I was thinking in the 550 range(he is a good customer)
I was looking at the wiring info on the 06 AUDI A4, looks like 2 Ignitions and 2 starters aside from that, everthing else seems the same.
anyone know if the 2006 and 2007 are the same?
Hey Velocity, I did a 2005 BMW X5, I found it long, which one would you consider harder to work on?
Testing is the key
Posted: October 28, 2007 at 3:24 PM / IP Logged
If it weren't for the CANSL2 module I would definitely say that the Audi would be harder to do than the BMW but seeing that the CANSL2 does alot of the work as far as outputs I would side with the BMW being a harder one to do ( stupid door locks being in the door module 2007 audi a4 -- posted image. what a pain in the butt )
