prostart 3200
opj38
Member - Posts: 31
Posted: November 01, 2007 at 10:06 PM / IP Logged
Hi, Installed a remote starter in a 95 civic. All wires are installed correctly. The only problem that I have is trying to program the remote. I flash the hood pin to get into programming mode, and then turn the key on and off and then push the 1 button on the remote and wait for the 5 flashes from the parking lites, and nothing. Did this 100s of times and nothing. Any help please. Oh this is a Canadian Tire Prostart 3200 with the 2 button remote.
lspker
Silver - Posts: 503
Posted: November 01, 2007 at 11:17 PM / IP Logged
press and hold lock till flashes, or sometimes press twice.
Check annt is plugged into proper slot.
dea,can
Copper - Posts: 284
Posted: November 03, 2007 at 4:30 PM / IP Logged
when u are programming  are your park lights coming on.hold for 4 secs let go park should come on push it again then quick once more  so 3 times
dragon
stangbanger242
Member - Posts: 19
Posted: November 28, 2007 at 4:07 PM / IP Logged
might be a faulty antenna. heard on these post some people having same problems
Support the TROOPS!!
schmoo
Copper - Posts: 62
Posted: November 28, 2007 at 5:45 PM / IP Logged
turn the key off/on/off then press the lock butoon repeatedly, that should get it to recognize the remote.  Done lots and that is a common hold-up on the unit.
a true canadian eh!
muaiad97
Copper - Posts: 207
Posted: November 29, 2007 at 8:33 PM / IP Logged
hi
just  do  this  ground  the hood pin and  push  the  programing  button on the sid of  the brain  push it and release it and push it release it  again  turn the key on  off then hold  the lock button til you get 5 flashing  light and u will be  ok
Monday, November 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
