2007 ford escape wiring diagram
todds440
Member - Posts: 48
Posted: November 06, 2007 at 7:50 AM / IP Logged
Anyone have the wiring in for a 2007 Ford Escape???
Twelvoltz
Platinum - Posts: 2,384
Posted: November 06, 2007 at 8:23 AM / IP Logged
Audiovox lists:
          #505408: 2004 ACURA CL 2DR COUPE
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          WHITE/ YELLOW          (+)          RADIO HARNESS
     Accesory          WHITE/ RED          (+)          RADIO HARNESS
     Ground          BLACK          (-)          RADIO HARNESS
     Illumination          RED / BLACK          (+)          RADIO HARNESS
     Dimmer          RED          (-)          RADIO HARNESS
     Power Antenna          YELLOW/WHITE          (+)          RADIO HARNESS
     Amp Turn On          YELLOW/WHITE          (+)          RADIO HARNESS
     LF Speaker (+)          WHITE
     LF Speaker (-)          ORANGE
     RF Speaker (+)          YELLOW
     RF Speaker (-)          BROWN
     LR Speaker (+)          RED
     LR Speaker (-)          GREEN
     RR Speaker (+)          BLUE
     RR Speaker (-)          BLACK
     Amp Location          MOUNTED TO BRACKET IN RIGHT SIDE OF TRUNK
     Steering Cntrls          YES
               THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTAR® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT.
     Speed Cntrl          NO
     Radio Security          YES
     Security
     Battery          BROWN AND ORANGE          (+)          PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PINS 12/33 OF 40 PIN PLUG
               PSC/ECU TO THE FAR RIGHT BEHIND GLOVE BOX
     Ignition 1          YELLOW          (+)          PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 35 OF 40 PIN PLUG
     Starter 1          BLUE          (+)          PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 15 OF 40 PIN PLUG
     All Door Trigger          BLACK/ WHITE          (-)          AT PLUG TOP OF FUSEBOX
     Domelight Super          BLUE
     LF Latch          RED          (-)          BECU PIN 14 OF A 16 PIN PLUG
               BECU IS ATTACHED TO PASSENGER FUSE BOX BEHIND GLOVE BOX
     RF Latch          RED          (-)          BECU PIN 23 OF A 28 PIN PLUG
     LR Latch          GREEN          (-)          BECU PIN 11 OF A 28 PIN PLUG
     RR Latch          BLUE          (-)          BECU PIN 16 OF A 16 PIN PLUG
     Trunk Trigger          RED          (-)          BECU PIN 11 OF A 16 PIN PLUG
     Hood Trigger          WHITE/ BLUE          (-)          HOOD PIN SWITCH UNDER HOOD
     Alarm Disarm          ARMS WITH LOCKS
     Alarm Arm          DISARMS WITH UNLOCK
               FIRST PULSE DISARMS SECOND PULSE UNLOCKS
     Parking Lights          GREEN          (+)          AT THE BACK OF PARKING LIGHT UNDER HOOD
     Low Crr Pk Lights          TEST
     Convenience
     Headlights-Lo          BLUE/RED          (-)          IGNITION SWITCH HARNESS
     LF Pk Lt Bulb          RED / BLACK          (+)          AT FRONT LEFT PARKING LIGHT
     RF Pk Lt Bulb          RED / BLACK          (+)          AT FRONT RIGHT PARKING LIGHT
     LR Pk Lt Bulb          RED / BLACK          (+)          AT REAR LEFT PARKING LIGHT
     RR Pk Lt Bulb          RED / BLACK          (+)          AT REAR RIGHT PARKING LIGHT
     Wipers-Lo          BLUE / YELLOW          (-)          IGNITION SWITCH HARNESS
     Trnk Release          LIGHT GREEN          (-)          BECU PIN 13
     Remote Start
     Ignition 2          LIGHT BLUE          (+)          PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN34 OF 40 PIN PLUG
     Accessory 1          GREEN          (+)          PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 11 OF 40PIN PLUG
     Starter 2          LIGHT BLUE          (+)          PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 17 OF 40 PIN PLUG
     Anti-Theft Type          UNIVERSAL TRANSPONDER
     Anti-Theft Descript          THE KEY SENDS A RF SIGNAL TO THE BCM THROUGH A ANTENNA AROUND THE KEY CYLINDER
     Key Sense          BLUE/WHITE          (-)          IGNITION SWITCH HARNESS
     Neutral Safety          GREEN / WHITE          (-)          AT GEAR SELECTOR SWITCH
     Tachometer          WHITE          (AC)          PIN 9 AT THE DATA CONNECTOR
     Speed Sense          PURPLE          (AC)          ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 14 OF A 26 PIN PLUG
     Low Crr. Pk Lights          TEST
     Brake Lights          RED / BLACK          (+)          BRAKE PEDAL
     Reverse Lights          RED          (+)          ECU PIN13
     Horn          YELLOW          (-)          STEERING COLUMN HARNESS
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          LIGHT GREEN          (-)          POWER MASTER SWITCH IN DRIVERS DOOR
     PowerLock          PINK          (-)          POWER MASTER SWITCH IN DRIVERS DOOR
               REQUIRES DOUBLE PUSLE
     Driver Mtr Unlock          RED          (REV)          ECU IN DRIVERS DOOR
     Driver Mtr Lock          GREEN          (REV)          ECU IN DRIVERS DOOR
     Pas Mtr Unlock          RED          (REV)          ECU IN PASSENGER DOOR
     LF Window Up          RED / YELLOW          (REV)          DRIVERS DOOR SWITCH
     LF Window Dn          RED / BLUE          (REV)          DRIVERS DOOR SWITCH
     RF Window Up          BLUE / YELLOW          (REV)          DRIVER KICK PANEL
     RF Window Dn          BLUE          (REV)          DRIVER KICK PANEL
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
techman93
Silver - Posts: 591
Posted: November 07, 2007 at 6:28 PM / IP Logged
I thought they asked for a 2007 Ford Escape?
Twelvoltz
Posted: November 07, 2007 at 6:43 PM / IP Logged
WOW, Did not even notice...happens with age I guess 2007 ford escape wiring diagram -- posted image.
Here is what they list, really it is...
          #510371: 2007 FORD ESCAPE 4DR SUV
     Audio/Mobile Video
     Battery          ORANGE / LT GREEN          (+)          RADIO HARNESS
     Accesory          YELLOW/BLACK          (+)          RADIO HARNESS
     Ground          BLACK/ GREEN          (-)          RADIO HARNESS
               ALSO CAN BE BLACK
     Illumination          LT BLUE/RED          (+)          RADIO HARNESS
     Amp Turn On          LIGHT BLUE          (+)          RADIO HARNESS
     LF Speaker (+)          ORANGE / LT GREEN
     LF Speaker (-)          LT BLUE/WHITE
     RF Speaker (+)          WHITE/ LT GREEN
     RF Speaker (-)          DK GREEN/ ORANGE
     LR Speaker (+)          TAN / YELLOW
     LR Speaker (-)          GRAY/LT BLUE
     RR Speaker (+)          ORANGE / RED
     RR Speaker (-)          BROWN / PINK
     Radio Security          YES
     Security
     Battery          TAN/BLACK          (+)          DRIVERS SIDE KICK PANEL HARNESS
               IF YOU CAN'T FIND THAT WIRE THAN USE BATTERY FOR 12 VOLTS
     Ignition 1          LT GREEN/ VIOLET          (+)          IGNITION SWITCH
     Starter 1          TAN/LT BLUE          (+)          IGNITION SWITCH
     All Door Trigger          VIOLET/ORANGE          (+)          DRIVERS SIDE KICK PANEL HARNESS
     Domelight Super          PINK          (-)          DRIVERS SIDE KICK PANEL HARNESS
     LF Latch          LT GREEN/ BLACK          (-)          SJB CONN D PIN 21
     RF Latch          DK BLUE          (-)          SJB CONN D PIN 20
     LR Latch          PURPLE / LT GREEN          (-)          SJB CONN D PIN 19
     RR Latch          PINK/LT BLUE          (-)          SJB CONN D PIN 18
     Trunk Trigger          WHITE/ PURPLE          (-)          SJB CONN D PIN 17
     Hood Trigger          PURPLE / ORANGE          (-)          SJB CONN B PIN 5
               THIS WIRE RESTS AT GROUND AND GOES TO AN OPEN CIRCUIT WHEN THE HOOD IS OPENED
     Alarm Disarm          DK BLUE/LT GREEN          (-)          DRIVERS SIDE KICK PANEL HARNESS
     Alarm Arm          WHITE/ PURPLE          (-)          DRIVERS SIDE KICK PANEL HARNESS
     Parking Lights          WHITE/ BLACK          (-)          STEERING COLUMN
               MAY ALSO BE VIOLET/WHITE AT SMART JUNCTION BOX ON PASSENGER SIDE OF CENTER CONSOLE
     Low Crr Pk Lights          BROWN          (+)          DRIVERS KICKPANEL
     Convenience
     Headlights-Lo          RED / YELLOW          (-)          STEERING COILUMN HARNESS
               ALSO AT SMART JUNCTION BOX ON PASSENGER SIDE OF CENTER CONSOLE
     Headlights-Hi          LIGHT GREEN/ BLACK          (-)          AT VEHICLE HEADLIGHT SWITCH
     All Hazrd Lights          RED / WHITE          (-)          AT VEHICLE HAZARD SWITCH
     Wipers-Lo          BLACK/ PINK          (+)          AT VEHICLE WIPER CONTROL SWITCH
     Wipers-Hi          DARK BLUE/ORANGE          (+)          AT VEHICLE WIPER CONTROL SWITCH
     Parking Brake          LT GREEN/ RED          (-)          AT SWITCH
               MAY ALSO BE FOUND AT SMART JUNCTION BOX ON PASSENGER SIDE OF CENTER CONSOLE
     Trnk Release          N/A          (-)          AT SMART JUNCTION BOX ON PASSENGER SIDE OF CENTER CONSOLE
     Fuel Dr Release          N/A
     Seat Mem 1          N/A
     Seat Mem 2          N/A
     Remote Start
     Accessory 1          BLACK/ LT GREEN          (+)          IGNITION SWITCH
     Anti-Theft Type          FORD PATS® OR SECURILOCK® VEHICLE IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          BLACK/ PINK          (+)          IGNITION SWITCH
     Tachometer          UNCOMMON SIDE OF INJECTOR OR COIL          (AC)          AT INJECTOR #1
               ALSO AT PCM MODULE ON PASSENGER SIDE OF ENGINE COMPARTMENT PIN #2
     Speed Sense          GRAY/BLACK          (AC)          AT ABS CONTROL MODULE ON DRIVERS DIE OF ENGINE COMPARTMENT
     Low Crr. Pk Lights          BROWN          (+)          DRIVERS KICKPANEL
     Brake Lights          LT GREEN          (-)          DRIVERS SIDE KICK PANEL HARNESS
     Reverse Lights          BLACK/ PINK          (+)          IN HARNESS IN DRIVER KICKPANEL
     Horn          YELLOW/LT GREEN          (-)          IGNITION SWITCH
     Modules
     WIRE          LOCATION
     Doorlocks/Windows
     Door Lock Circuit          3 WIRE NEG
     Power Unlock          PINK/WHITE          (-)          DRIVERS SIDE KICK PANEL HARNESS
               USES A STRAIT (-) TRIGGER FOR UNLOCK, SAME WIRE AS LOCK,
     PowerLock          PINK/WHITE          (-)          DRIVERS SIDE KICK PANEL HARNESS
               USE A 1K OHM RESISTOR FOR LOCK, USES SAME WIRE FOR UNLOCK,
     Driver Mtr Unlock          RED / ORANGE          (REV)          DRIVERS SIDE KICK PANEL HARNESS
     Driver Mtr Lock          PINK/BLACK          (REV)          DRIVERS SIDE KICK PANEL HARNESS
     Pas Mtr Unlock          PINK/ORANGE          (REV)          PASSENGER SIDE KICK PANEL
     LF Window Up          WHITE/ BLACK          (REV)          DRIVERS WINDOW SWITCH
     LF Window Dn          RED          (REV)          DRIVERS WINDOW SWITCH
     RF Window Up          TAN/LT BLUE          (REV)          DRIVERS KICK PANEL
     RF Window Dn          WHITE/ YELLOW          (REV)          DRIVERS KICK PANEL
     LR Window Up          YELLOW/BLACK          (REV)          DRIVERS KICK PANEL
     LR Window Dn          RED / BLACK          (REV)          DRIVERS KICK PANEL
     RR Window Up          GRAY/ORANGE          (REV)          DRIVERS KICK PANEL
     RR Window Dn          YELLOW/LT BLUE          (REV)          DRIVERS KICK PANEL
