Posted: November 07, 2007 at 11:06 PM / IP Logged
Posted: November 07, 2007 at 11:52 PM / IP Logged
Posted: November 08, 2007 at 4:16 AM / IP Logged
Posted: November 08, 2007 at 5:27 AM / IP Logged
Posted: November 08, 2007 at 6:37 AM / IP Logged
Posted: November 08, 2007 at 8:42 PM / IP Logged
Posted: November 29, 2007 at 9:43 PM / IP Logged
Posted: December 13, 2007 at 2:49 AM / IP Logged
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
You can pull the bottom of the steering wheel cover off after removing 2 screws. to the left you will find your ignition switch wires, which with the battery disconnected you can unplug for easier access.
Get the antenna ring of the bypass around the ignition switch tumbler like in the pics below
On the bypass connect the red to 12v, black to ground, and blue to the blue status output of the alarm.
