03 trailblazer remote start
jpinusmc
Member - Posts: 22
Posted: November 13, 2007 at 1:47 PM / IP Logged
I have an autopage rs-900 installed in a 2003 trailblazer. I have the 457g and the 555l installed.  The car will not remote start.  I have tested and starter, ignition and acc have 12v at the proper times but nothing is happening.
One thing i was wondering...
There are two yellow wires coming from the key area in the ignition harness.  One goes to the key and one goes to a cylinder looking deal with a button that goes in and out with the turn of the key.  Which one of these should I be using for the 555l?  Is there a way to test them to make sure I have the right one?
Any help is much appreciated.
Twelvoltz
Platinum - Posts: 2,384
Posted: November 13, 2007 at 3:25 PM / IP Logged
One is the mechanical safety lock the other is your passlock. The ones not running to the 'actuator' but to the key cylinder itself are your passlock wires.
jpinusmc
Member - Posts: 22
Posted: November 13, 2007 at 4:13 PM / IP Logged
Sweet, got it straightened out, thanks a bunch!
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
