2008 Jeep Patriot, Huratai HT-800D+ Remote Start/Alarm
pidpid
Posted: November 25, 2007 at 10:03 AM / IP Logged Link to Post Post Reply Quote pidpid
2008 Jeep Patriot installing Huratai HT-800D+ remote start with alarm.
trying to get start relay to connect starter wire to ground through 180 ohm resistor.
Woks with key in and in start position, and manually connecting resistor from ground to violet/brown ignition switch harness (starter wire)
When press start on remote, the remote start chirps 3 times and does not attempt anything.
the remote control does arm and dis-arm vehicle.
no door locks are used at this time, just want to remote start vehicle for now.
I think issue with  Huratai device as the starter yellow wire does not have 12 volts when trying to start
- just 3 chirps instead of one chirp and then start attempt.
Any ideas? or someone else have this problem? Thanks.
Below is remote start wiring diagram.
2008 Jeep Patriot, Huratai HT-800D+ Remote Start/Alarm -- posted image.
