2007 hyundai elantra remote start
Alpine Guy
Platinum - Posts: 2,478
Posted: November 30, 2007 at 8:55 AM / IP Logged
Im going to be doing a starter install on a 2007 Elantra on site at a customers house today and im looking for all the hints and tips on doing this car please. I will be using a key in the box type bypass and im a little stumped about this key sense hookup if someone can help me find the easiest way to do that. I will be doing door locks and the trunk also.
Here's the wire diagram i'll be working off of.
DEI Lists:
DIRECTWIRE™ WIRING INFORMATION - HYUNDAI / ELANTRA / 2007 / Remote Start
[PRINT THIS PAGE]
12volts      black (40A), red (30A)       +       ignition harness
Starter      white       +       ignition harness
Second Starter      N/A
Ignition      blue       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      pink       +       ignition harness
Second Accessory      yellow       +       ignition harness
Keysense      green       +       ign harn or BCM, wht 24P plug, pin 4
Notes: The BCM (Body Control Module) is in the center dash, behind the A/C controls.
Power Lock      green       -       dr kick or BCM, wht 20P plug, pin 3
Power Unlock      yellow       -       dr kick or BCM, wht 20P plug, pin 11
Lock Motor      gray       5wi      driver kick, gry 39 pin plug, pin 38
Unlock Motor      yellow       5wi      driver kick, gry 39 pin plug, pin 30
Parking Lights+      yellow (L), BROWN / orange (R)       +       fuse box, 30 pin plug, pins 22 and 6
Parking Lights-      blue       -       switch or BCM, wht 20P plug, pin 4
Hazards      green       -       BCM, gray 24 pin plug, pin 9
Turn Signal(L)      yellow/orange       +       switch or fuse box, 30P plug, pin 26
Turn Signal(R)      blue       +       switch or fuse box, 30P plug, pin 11
Reverse Light      gray or brown       +       fuse box, 30 pin plug, pin 13 or 14
Door Trigger      yellow       -       dr kick or BCM, wht 24P plug, pin 22
Dome Supervision      yellow       -       dr kick or BCM, gry 24P plug, pin 1
Trunk/Hatch Pin      green to GREEN/ black       -       dr kick or BCM, wht 24P plug, pin 23
Hood Pin      green       -       pin sw or BCM, wht 24P plug, pin 24
Trunk/Hatch Release      white       -       dr kick or BCM, wht 20P plug, pin 13
The trunk release motor wire is orange (+) in the fuse box, 30 pin plug, pin 28.
Power Sliding Door      N/A
Factory Alarm Arm      green       -       dr kick or BCM, wht 20P plug, pin 1
Notes: Meter this wire while turning the key in the driver door key cylinder.
Factory Alarm Disarm      blue to yellow       -       dr kick or BCM, wht 20P plug, pin 2
Disarm No Unlock      with ign, acc, and key sense
Tachometer      blue or red       ac       pass kick, gray 39 pin plug, pin 5
Notes: Also found at the instrument cluster, white plug, pin 20.
Can also go to any fuel injector and use the wire that is NOT white.
Wait to start      N/A
Brake Wire      white to black       +       sw or dr kick, gray 39P plug, pin 34
Parking Brake      blue       -       sw or fuse box, 20 pin plug, pin 8
Horn Trigger      red or GREEN/ orange       -       switch or BCM, gry 24P plug, pin 8
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Only Canadian models have the immobilizer system.
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
You would need to energize keysense, yes. If you look at the notes for disarm/no unlock it specifies that the factory alarm will disarm with keysense, ignition and accessory. You do not mention which system you are installing, but with the DEI systems I use there is a status output wire that you would use to power a relay to provide +12V to the vehicle's keysense wire during remote start. You may also be able to just use the second ignition output to power it if your vehicle does not require both accessories for remote start.
another-kelly
Silver - Posts: 618
Posted: November 30, 2007 at 7:30 PM / IP Logged
probably too late, but all you need to hook up on the bypass (assuming it's a 556u) is power, ground, and status. if for whatever reason the car shutdown when trying to do the key takeover then hookup keysense. very few cars ever do though
Alpine Guy
Posted: November 30, 2007 at 9:10 PM / IP Logged
Yeah, i already did the install, everything went well until the brain fried..gota go back tomorrow :(
For future if people look this thread up, don't try to go to the BCM, it's a bitch, get everything in the kick panel!
And the key sense wire is an GREEN/ orange in the ign harness.
tedmond
Gold - Posts: 4,610
Posted: November 30, 2007 at 10:44 PM / IP Logged
how u fry the brain?
Alpine Guy
Posted: December 02, 2007 at 3:18 PM / IP Logged
It just shorted out for no reason, I have had two Autostart products do that in the past week, never installation error, each time a new unit was plugged in and worked flawlessly.
However now I am having an issue, I picked up a key in the box type security bypass with the stick on ring antenna, but it will not work unless the ring is outside in front of the key cylinder, so im looking for a better type of bypass, is there any recommendations??
Also, where have you guys gotten the alarm disarm wires? I could not locate it.
KarTuneMan
Platinum - Posts: 7,056
Posted: December 02, 2007 at 6:20 PM / IP Logged
FACTORY ARM Green In harness from driver's door   -
 FACTORY DISARM Blue In harness from driver's door   -
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
