1995 buick regal alarm/rs
shadowinfector
Copper - Posts: 199
Posted: December 03, 2007 at 12:48 PM / IP Logged
1995 Buick Regal Alarm/RS
I am about to install an alarm/rs on this vehicle. Can someone provide me with wiring diagram and any helpful hints. Thanks Alot
Twelvoltz
Platinum - Posts: 2,384
Posted: December 03, 2007 at 1:32 PM / IP Logged
https://www.the12volt.com/installbay/alarmdetail/362.html
KarTuneMan
Platinum - Posts: 7,056
Posted: December 03, 2007 at 1:42 PM / IP Logged
12 VOLTS Red Ignition harness   +
 IGNITION pink Ignition harness   +
 ACCESSORY Orange Ignition harness   +
 ACCESSORY 2 Purple Ignition harness   +
 STARTER Yellow Ignition harness   +
 KEY SENSE Lt.green Ignition harness   -
 TACH SIGNAL PURPLE / white At coil on engine   AC
 LOCK Blue In driver's kickpanel   +
 UNLOCK White In driver's kickpanel   +
 DOORPIN White At courtesy light under dash   -
 TRUNK RELEASE Black At release switch in dash   +
 FACTORY DISARM Lt.green In driver's kickpanel   -
 BRAKESWITCH White At switch above brake pedal   +
 PARKLIGHTS Brown At light switch harness   +
 HORN Black At steering column harness
shadowinfector
Copper - Posts: 199
Posted: December 12, 2007 at 10:10 AM / IP Logged
is there anything out of the ordinary on this car??
KarTuneMan
Posted: December 12, 2007 at 7:54 PM / IP Logged
See my above post!.
