2006 2008 honda gauges into a 2004 blazer
z3r0 her0
Posted: January 12, 2009 at 9:10 PM / IP Logged
Hello,
I have a 2004 Chevy Blazer and I want to replace the factory gauge cluster with one from a 2006 - 2008 Honda Civic. I know that they are both completely different, and that I will have to do my own wiring to make it work. Does anyone have any advice on how to do this.... and where I can find wiring diagrams for the gauge clusters on these two vehicles?
CutDog504
Silver - Posts: 643
Posted: January 24, 2009 at 2:17 PM / IP Logged
I think this would be a super easy swap. All you need is your magic wand and a bit of fairy dust. DONE.
lspker
Silver - Posts: 503
Posted: January 24, 2009 at 10:52 PM / IP Logged
Actually its really easy, just ues a plasma cutter and cut the inside of the blazer to fit the out side of the honda, and you get the added benifit of better gas milages.
KPierson
Platinum - Posts: 3,527
Posted: January 25, 2009 at 12:07 AM / IP Logged
Start by getting the factory service manuals to both cars.
If the Civic cluster uses any sort of communicaiton protocol you can pretty much give up now.
If you are extremely lucky and find that all the gauges actually have analog signals directly driving them then all you will have to do is scale the values in the Blazer to match those in the Honda.
That is best done with fairy dust, as mentioned above.
Kevin Pierson
