93 Ford F-150 under rear seat sub enclosure
Sound Pressure
Silver - Posts: 711
Posted: August 09, 2002 at 12:45 AM / IP Logged
Hi,
Does anyone happen to have any pics or suggestions on building a sub enclosure for 2 twelves under the rear seat of an F-150 93 extended cab not quad? Has anyone ever tried raising the rear seat to do this? If so what all was envolved, any tips?
Thanks,
Sound Pressure
gotoevolution
Member - Posts: 17
Posted: August 20, 2002 at 10:26 PM / IP Logged
Well ive done 4 10's under the seat of a '98 F150 but you need to let me know what kind of subs your going to use cause the air space needs to be calculated, and as for tips i recommed when making the box facing the subs downwards and on each side of the box place a small piece of wood under so that the subs do not touch the hit the floor when you are bassing.
Learn to evolve, EVOLUTION
Sound Pressure
Silver - Posts: 711
Posted: August 21, 2002 at 10:35 PM / IP Logged
Thanks goto but the rear seat on a 93 is set right on the floor. You can probalby only raise the seat about 6 inches max without hitting your head on the roof. I think that he is going to buy Kenwood 12's from Best Buy. Maybe a 1 cube box each. Wondering which way may sound better for that speaker? Bandpass, sealed, ported?
Sound Pressure
Sound Pressure
Silver - Posts: 711
Posted: August 28, 2002 at 11:02 PM / IP Logged
Just an update,
The box is done. Just needs carpet and hook up of all wires and fine tunning and it ahould be set, unfortunately I do not have a digital camera to show it but I will be looking for one.
Sound Pressure
