'00 Mustang Auto Start
Stangman98
Member - Posts: 9
Posted: December 11, 2002 at 1:02 PM / IP Logged
Just wondering if there are any tips or tricks to the install. I am going to be installing an Astrostart 1105 in a '00 Mustang V6. What kind of time frame am I looking at on this? Is it a nessisity to install the Hood Pin also? Any help would be greatly appreciated. I am not at all new to car audio/security but this is my first full on auto start
1998 Award Winning Mustang GT
da6foota
Posted: January 02, 2003 at 7:51 PM / IP Logged
 hey check it out,if you don't have a factory alarm ,then you will have no problems.just tie into the wire's coming off your ignition switch.if there are two yellow wires(about 22 gauge) very small do not touch !ford has been pretty consistent with it wire color's since 1990.also make sure you have a tach input to your remote starter.by the way make sure you test each wire to ensure you have the righjt lead .my email address is da6foota@yahoo.com.
da6foota
Platinum - Posts: 12,488
Posted: January 02, 2003 at 11:47 PM / IP Logged
watch out for the GEM on the door trigger wires if you are installing an alarm as well. Here is the wiring information on this car and you also have PATS II on this vehicle:
|              12V|yellow & lt. grn/pur|+  |ignition harness            |
|          STARTER|WHITE/ pink          |+  |ignition harness            |
|         IGNITION|RED / lt. green       |+  |ignition harness            |
|  SECOND IGNITION|gray / YELLOW         |+  |ignition harness            |
|        ACCESSORY|BLACK/ lt. green     |+  |ignition harness            |
| SECOND ACCESSORY|RED / black           |+  |ignition harness            |
|       POWER LOCK|lt. green           |+  |low in drivers kick or *1   |
|     POWER UNLOCK|purple              |+  |low in drivers kick or *1   |
|       LOCK MOTOR|RED / white           |   |low in drivers kick or *1   |
|     UNLOCK MOTOR|RED / orange          |   |low in drivers kick or *1   |
|    DISARM DEFEAT|pink/orange         |   |GEM module *1               |
| PARKING LIGHTS +|brown               |   |light switch or drivers kick|
| PARKING LIGHTS -|WHITE/ black         |   |*1                          |
|       HEADLIGHTS|RED / yellow          |+  |light switch                |
|     DOOR TRIGGER|*2                  |-  |*2                          |
| DOME SUPERVISION|BLACK/ white         |+  |drivers kick panel or *1    |
|  TRUNK/HATCH PIN|BROWN / white         |-  |drivers kick panel or *1    |
|TRNK/HTCH RELEASE|purple / YELLOW       |+  |drivers kick panel          |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|dk. GREEN/ purple    |-  |drivers kick panel or *1    |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|*3                  |   |*3                          |
|      SPEED SENSE|WHITE/ orange        |   |PCM pin 68 *4               |
|       BRAKE WIRE|RED / lt. green       |+  |brake switch                |
|     HORN TRIGGER|yellow/lt. green    |-  |steering column or *1       |
|           WIPERS|white & dk. blu/orn |+  |wiper motor                 |
|  LF WINDOW UP/DN|wht/blk - wht/blk   |A  |drivers window motor        |
|  RF WINDOW UP/DN|tan/blu - wht/yel   |A  |drivers kick panel          |
|  LR WINDOW UP/DN|yel/blu - gry/orn   |A  |drivers kick panel          |
|  RR WINDOW UP/DN|yel/blk - RED / blk   |A  |drivers kick panel          |
|        RADIO 12V|lt. GREEN/ violet    |   |at the radio                |
|     RADIO GROUND|black               |   |at the radio                |
|     RADIO SWITCH|BLACK/ pink          |   |at the radio                |
| RADIO ILLUMINATE|lt. blue/red        |+  |at the radio                |
|    POWER ANTENNA|ORANGE / lt. blue     |+  |at the radio                |
|       LF SPEAKER|orn/grn - blu/wht   |   |at speaker or amplifier *5  |
|       RF SPEAKER|wht/grn - grn/orn   |   |at speaker or amplifier *5  |
|       LR SPEAKER|gry/blu - tan/yel   |   |at speaker or amplifier *5  |
|       RR SPEAKER|orn/red - brn/pnk   |   |at speaker or amplifier *5  |
Notes:
NOTE: This vehicle has the PATS anti-theft system.  *1 Also found at the GEM module located above the drivers kick panel to the drivers side of the steering column.  *2 There are two door trigger wires. Use yellow/black for the drivers door and gray/red for the passengers door. Both wires are found above the drivers kick panel in a 20 pin connector. Use both wires and diode isoate each. See direct fax document #1076 for wiring information.  *3 For the 3.8L motor, use the dk. blue/lt. green, RED / lt. blue, or the pink/white. All of these wires are found at the coil pack. The 4.6L motor uses a separate coil for each cylinder. Go to any coil and use the wire that is NOT red or WHITE/ lt. blue.   *4 The PCM is located behind the passenger kick panel.   *5 The amplifier is located just below the radio.
da6foota
Posted: January 06, 2003 at 7:21 AM / IP Logged
Yes,put the hood switch in ,because some remote starters all you do is touch(barely)the key fob  button and the car starts.Wouldn't that be suprising if you ahave your hands in the accessories are,your changing oil and the car start.Very Ugly!
da6foota
