01 cavalier z24 odometer error
Supertom
Member - Posts: 25
Posted: June 04, 2006 at 9:38 PM / IP Logged
Hi all,
My 01 cavalier Z24 has ERROR on the Odometer screen and will not show anything but that, no numbers on odometer or trip, can anyone help.
TommyB
pss5075104
Copper - Posts: 144
Posted: June 13, 2006 at 1:10 PM / IP Logged
try letting the car sit for 1 hr with batt unhooked, and see if that helps.
D
MECP First Class Certified Installer.
Nothing is impossable, it's just more expensive.
auex
Platinum - Posts: 5,041
Posted: June 18, 2006 at 12:32 PM / IP Logged
Is there a cel or mil? Try resetting it like mentioned. You should probably go to autozone and see if they can pull a code from the obd2 port. It sounds like a problem with the ECU.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
