Door Locks
stealth170
Posted: February 12, 2003 at 4:42 AM / IP Logged
I have a 1999 dodge caravan.I'am hooking up a remote to unlock the doors. I have talk to some people and they say i need a 1500 ohm resistor for the lock and a 250 ohm resistor for the unlock. First question is a resistor the same as a relay like a 30amp relay. If it is the same can i use a 30amp relay for both lock & unlock. If not where do i get a resistor and how do you hook it up to a one wire door lock system. Because my alarm has 4 wires 2 for the lock and 2 for the unlock & the a hot wire. Any help with this would be great.         THANKS
        Stealth
Player69
Silver - Posts: 504
Posted: February 12, 2003 at 10:20 AM / IP Logged
https://www.the12volt.com/doorlocks/page2.asp  Go here and scroll Down to the dodge caravan.
