unlocking a wheel
snakebite129
Posted: October 13, 2007 at 10:10 PM / IP Logged
To unlock a steering wheel on say a 04 Lancer or any car for that matter is there a wire that simply needs to see voltage/ground to unlock it?  For example a keysense wire or are there actual sprockets and gears that need to be turned to unlock a steering wheel.
KarTuneMan
Platinum - Posts: 7,056
Posted: October 14, 2007 at 10:45 PM / IP Logged
If you have a key......it's a NON question.
What is it that you are attempting ???
snakebite129
Posted: October 14, 2007 at 11:40 PM / IP Logged
Well to start it is my car, I'm not trying to steal anything.  What I am doing is wiring up two relays with a small switch assembly to start my car.  There is no chip to be bypassed.  I just want to know ahead of time whether or not the wheel will unlock via power to ignition circuit or power (ground in my case) to the keysense wire.  And to all the other people that have viewed this post without responding......Yes it will work as far as me starting everything without a key.  Stay tuned to see if it the wheel will actually be turnable.  unlocking a wheel -- posted image.
