extra lights on atv
hondatim
Posted: December 20, 2007 at 7:46 PM / IP Logged
I want to add two light to my atv to come on with high beams how do I wire it up. I got some
12VDC LD-12P 30A / 40A REC Relays spdt so what wire go's to what pin. Do I need any diodes.
Thank you tim
tedmond
Gold - Posts: 4,610
Posted: December 21, 2007 at 4:37 PM / IP Logged
kk relay setup
85 - ground
86 - connect to high beam wire that shows 12volts when high beam active.
70 - Constant 12volts (high current)
30 - to 12v wire of lights, and just ground the negative wire.
You will need to place a diode on the coils (rectifing diode) usaully the 400 series. For your situation using a 1N4002 to 1N4004 would be best. Place the diodes cathode side (white stripe) to Pin 86, and the anode of diode(black) to Pin 85.
Monday, August 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
