active alarm without power consumption?
ludapower
Posted: August 03, 2009 at 6:13 PM / IP Logged
Is it possible to have a setup where you have an alarm and once you break a wire, the alarm instantly goes off, yet when the wire is connected it doesn't consume any power from the battery.
Hopefully you can understand what I'm trying to describe.
Platinum - Posts: 13,726
Posted: August 03, 2009 at 10:04 PM / IP Logged
They do make Back-Up battery sirens.  They do what you are wanting it to do.  But it does draw a little current from the battery.
Posted: August 04, 2009 at 1:45 AM / IP Logged
Current draw on a battery back-up siren is negligable. And why not tell us what vehicle or alarm yu have or are considering, it might just be relevant.
dualsport
Silver - Posts: 983
Posted: August 08, 2009 at 8:35 AM / IP Logged
Negligible yes, but zero power consumption not really, since everything needs power to work.
If you simply use a transistor that's kept off by your monitoring wire keeping the input grounded, you could have it switch turn on when the wire's broken.
The input gets pulled up high, and the transistor turns on your siren.
The small amount of pullup current is the power that would be needed in standby, but it would only be 12 microamps if you used a 1M ohm pullup. Definitely negligible, but technically not zero.active alarm without power consumption? -- posted image.
boxhead78
Copper - Posts: 84
Posted: October 18, 2009 at 12:21 AM / IP Logged
regardeless to how you do it .it will take some power
boxead78
hotwaterwizard
Silver - Posts: 1,350
Posted: October 22, 2009 at 9:37 PM / IP Logged
You can not get something from nothing.
Electrons must have a current to make it flow.
Think of a puddle of water sitting in a hole. Something must happen to make it flow.
The wind can blow and move the water but, wind is energy.
Gravity is also energy that can make the water flow.
Evaporation is another way to make water flow upwards but, it takes Heat which is also energy.
Perpetual Motion is a Myth.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
