window wiring, relay troubleshoot
killerkid
Posted: November 06, 2009 at 5:59 PM / IP Logged
2002 pontiac sunfire se.... it seems as if the window motor is going bad, it will go up and down sometimes and is getting worse, but it works alright when i turn the car off and back on then it will work and stop again so i just want to know if there are relays or areas i could check befor i go by a new window motor and its not the problem...
killer kid
Platinum - Posts: 13,723
Posted: November 06, 2009 at 6:43 PM / IP Logged
I would check the switches before anything else.
Posted: November 07, 2009 at 2:57 AM / IP Logged
Try thoroughly spraying the channels with WD40, also is the glass aligned properly?
Sunday, October 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
