Posted: February 19, 2010 at 2:20 PM  / IP Logged
Posted: February 20, 2010 at 3:16 AM  / IP Logged
Posted: February 20, 2010 at 9:22 AM  / IP Logged
Posted: February 20, 2010 at 4:19 PM  / IP Logged
Posted: March 02, 2010 at 6:18 PM  / IP Logged
Posted: March 02, 2010 at 6:43 PM  / IP Logged
| You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
My goal here is to control one fan with the controller and use a relay to activate another fan at the same time. I can think of two ways to do this. I am sure there are probably other ways too.
A
B
Which is the best way? Is there a better way I am unaware of?
Moving on, my controller requires a switched +12v ign source(which I can get from the ignitor), and an a/c clutch trigger wire.
I can think of a few ways to do this also.
A1
B1
C1
Which would cause the least impact on the factory system?
Sorry again for posting something so simple. I really just cant figure out the proper way to utilize a relay.
also I dont understand what this means "with diode connection from the AC etc. "
I know alternators have diodes but that is the extent of  my knowledge.
Also I am interested in that last thing you mentioned. Could two fans that draw ~7.5amps cause a significant spike?
& Thank you so much for the help!
will that work? will it allow one fan/relay to work if one fan/relay fails?
