Simple Way to Make a Time Delay Relay?
southface
Posted: November 02, 2010 at 7:16 AM / IP Logged
Hi
Sorry if I'm posting something that someone else has answered. I really did check and could not find anything!
I'm looking to build a simple circuit that will activate a relay but with a short time delay. I understand this means I need a normally-open, timed-closed relay, or a simple circuit that can act like one.
It will use 12V DC on the coil. I'd like the relay to be normally open and only close after about half a second of continuous charge/current on the coil contacts. I understand it may be possible to do this by simply using a capacitor and a resistor with a standard 12V relay. Is there anyone who has details who can help, for example:
- how do I wire the capacitor and resistor to the relay?
- what sizes do I need?
Paul
Platinum - Posts: 13,725
Posted: November 02, 2010 at 5:27 PM / IP Logged
Do you have any capacitors available?  If so, what values do you have?
southface
Posted: November 03, 2010 at 12:22 AM / IP Logged
I don't, but I am willing to go and buy the value I need.
rock61992
Posted: January 16, 2011 at 3:58 PM / IP Logged
I need the exact same thing, but i also need it to delay in shutting off for about half a second as well. I guess its just getting a capacitor to discharge onto the coil after the trigger current is off but i have no idea how to wire it or if i would need diodes in certain spots. Any advice or a wiring diagram would be much appreciated, Thank you.
For clarity...
I need a relay to contol the timing of another circuit with about a half second delay going on and off.
oldspark
Gold - Posts: 4,913
Posted: January 16, 2011 at 6:50 PM / IP Logged
You can't do BOTH using simple Rs & Cs and diodes. (Not without using several relays....)
IMO these tings are better done by circuitry anyhow - ie, semiconductors, chips etc.
hotwaterwizard
Silver - Posts: 1,350
Posted: February 16, 2011 at 12:38 AM / IP Logged
What you want is called an On Delay. There are several ways to do this.
Simple Way to Make a Time Delay Relay? -- posted image.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
oldspark
Gold - Posts: 4,913
Posted: February 16, 2011 at 12:58 AM / IP Logged
PEDantic: In the last fig, #85 & #86 should be swapped...
(Convention is #85 is -ve or GND; #86 is +ve.)
....but this only matters if the relay has an in-built spike-quenching diode.
(Which I hate for that polarity reason - I prefer to wire such diodes in the socket/harness so I can use ANY relay (suppressed or not).
And IMHO as usual - hotwaterwizard so often supplies a great collection of circuits or circuit ideas. (Well worth waiting for!)
Now - a simpler FET delay....????
hotwaterwizard
Posted: February 17, 2011 at 9:56 PM / IP Logged
http://www.bowdenshobbycircuits.info/page2.htm#relay_i.gif
Stockton California
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
