Ahh-- make it stop!
BumpNGlow
Member - Posts: 43
Posted: April 20, 2003 at 12:01 AM / IP Logged
My relays clicks... I have it hooked up to an interface so that every time the music "hits" it changes the color of the lights.... well it clicks a lot and its very loud...
What have ppl done in the past to dampen in the sound?  I have duct tape, sound dampening material, and foam... hehe, what should I do?
KBToys
Copper - Posts: 74
Posted: April 21, 2003 at 6:57 AM / IP Logged
I don't think there is much you can do.
Platinum - Posts: 12,488
Posted: April 21, 2003 at 8:39 AM / IP Logged
Relocate the relay to the trunk if it bothers you.
chkdsk
Member - Posts: 35
Posted: April 21, 2003 at 10:40 AM / IP Logged
I have seen quiet 12V Relays advertised somewhere so I did a quick search on Google and found this page: http://www.fcai.fujitsu.com/relays/archive/twinrelay.asp
Although I haven't used them persoanlly, they advertise themselves as being ultra quiet - this may help you out.
BumpNGlow
Member - Posts: 43
Posted: April 21, 2003 at 12:54 PM / IP Logged
awesome... that looks like it will work but I have a question:
Can someone verifty for me(it looks like it but I don't know much about different types of relays) that this is a standard 5 pin relay like my Bosch relay is?
http://www.fcai.fujitsu.com/cgi-bin/shProd01.asp?part_ID=3829&srchType=Relay
Posted: April 21, 2003 at 1:04 PM / IP Logged
Yes it is. From the looks of the last page on the pdf. this is a SPDT relay.
chkdsk
Member - Posts: 35
Posted: April 21, 2003 at 1:05 PM / IP Logged
It appears to be a normal 5-pin style BUT the physical location of the pins don't appear to be the same so your Bosch style plug won't fit properly.
Here is their pin-outs:
Ahh-- make it stop! -- posted image.
Which is the same as a normal Relay. I will check around some more to see if I can find a "quiet" relay with a normal plug.
BumpNGlow
Member - Posts: 43
Posted: April 21, 2003 at 1:07 PM / IP Logged
Thanks for both of the quick responses..... Awesome.  My problem is solved :D!  Now does anyone know where I can order online?
chkdsk
Member - Posts: 35
Posted: April 21, 2003 at 1:08 PM / IP Logged
Uhhh... Image didn't appear correctly above. You can view it here:
http://spam.portage.net/Relay1.GIF
chkdsk
Member - Posts: 35
Posted: April 24, 2003 at 3:43 PM / IP Logged
BumpNGlow,
I have searched everywhere on the Internet to find a place where you can purchase those "quiet" relays and I can't find anywhere to save my life...
In Canada, we have a "Big Box Store" called Canadian Tire and they have them right on the shelf in the automotive section AND they plug into a normal relay plug. Maybe take a tour to some of your local automotive retailers and check on the shelf...
Page of 5
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
