Posted: August 03, 2012 at 3:35 PM / IP Logged
Posted: August 03, 2012 at 7:39 PM / IP Logged
Posted: August 04, 2012 at 12:58 AM / IP Logged
Posted: August 05, 2012 at 1:07 PM / IP Logged
Posted: August 05, 2012 at 1:08 PM / IP Logged
Posted: August 06, 2012 at 3:15 AM / IP Logged
Posted: August 06, 2012 at 4:15 AM / IP Logged
Posted: August 06, 2012 at 4:33 AM / IP Logged
Posted: August 06, 2012 at 4:49 AM / IP Logged
Posted: August 06, 2012 at 5:32 AM / IP Logged
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I am attempting to do the following relay setup. I am wanting to use a 12V+ ignition wire to activate the setup and for it to return to a off position after the ignition looses power. Is there a way to do that with this setup or would I have to add a additional relay to the ignition wire? Thanks
That diagram's +12V should be IGN +12V so that it deactivates with IGN off.
The "+12V out" can be the aircon if that IGN +12V has enough current rating, though I'd probably recommend the 12V out feeds another relay (#86) that connects an appropriate or new fused +12V from the battery (#30) to the aircon (#87).
The second relay not only takes the load of the "latching relay's" IGN +12V, but also allows future signals to kill the aircon - eg, aircons often turn off at low revs or idle. IE - a low RPM signal could break the 2nd relay's GND (#85) or +12V signal (#86).
FYI - that diagram exists in various places, but the12volt's
... where the circuit is powered by IGN +12V.
And the output controls the relay.
I suspect it powers up in the on state (+12V out), hence connect that to a relay connected to IGN +12V...
Or any flip-flip or divide-by-2 circuit (eg, the CD4017 can be div-2 to div-10 etc).
Or an on-off switch - push-button or rotary...
