Posted: February 02, 2013 at 8:48 PM / IP Logged
Posted: February 02, 2013 at 11:08 PM / IP Logged
Posted: February 03, 2013 at 9:41 AM / IP Logged
Posted: February 03, 2013 at 9:54 AM / IP Logged
Posted: February 03, 2013 at 9:57 AM / IP Logged
Posted: February 03, 2013 at 9:59 AM / IP Logged
Posted: February 03, 2013 at 6:25 PM / IP Logged
Friday, March 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
this site has against Junior Members. Alas I'm way too old to remember such details, but as I recall, posting images was part of that. If its a URL, merely paste its text in your reply.
(BTW, that "discrimination" is good wrt spammers etc, but it is a PITA for bonafide users.)
I'm still vague as to your wiring from your verbal.
However, if the relays are switching the strobes and the fan, and both the fan +12Vs from the #30s (else #87s) are joined together, then that's your cross-connect. IE - turn on either of the strobes and the +12V goes thru the fan +12V to the other strobe.
If so, then you need an "isolating diode" in each of the +12V fan feeds.
So what current consumption is your fan? That determines the current rating of the diodes. (Voltage rating isn't an issue since power diodes are usually rated for at least 50V.)
If under 1A, then 1N400x diodes.
If under 3A, then 1N540x diodes.
If above 3A - or even 1A - then using a 3rd relay may be better or easier than larger diodes...
OR if you don't want the ~0.7V diode voltage drop to effect you fan, then the 2 IN400x diodes join to energise a extra "fan relay" (#86) instead of the fan +12V.
Assuming you are switching/feeding +12V, then the diode line-ends are the joined outputs.
Click on the
