1993 lexus gs300
bringmeacar
Posted: April 28, 2013 at 7:58 PM / IP Logged
I have a gs300 that I just bought, I got it for a good deal and that's because all but the drivers window was not working. I thought it would be a master switch or something of that sort. I checked for fuses but the Lexus dealership said there is only relays so I need to know if anyone out there knows about my problem im having
Patrick Christopher
oldspark
Gold - Posts: 4,913
Posted: April 28, 2013 at 11:27 PM / IP Logged
LOL...
#1 - change your Lexus dealership. The circuit probably has a circuit breaker, else a fuse.
Rotate all like-sized fuses.
Rotate all like-sized circuit breakers else substitute and equivalent fuse for testing.
Disconnect and reconnect relevant connectors
After that it's probably a case of an orderly test with a test light or DMM.
Platinum - Posts: 13,726
Posted: April 29, 2013 at 12:04 AM / IP Logged
I think the dealer was saying that there is not a fuse or breaker for each door. The switch is where I would start looking.
Posted: April 29, 2013 at 1:13 AM / IP Logged
X3 with Oldspark and Mr. I.
oldspark
Gold - Posts: 4,913
That'd probably be correct, but there will (still) be a "master" fuse or CB for the circuit.
Posted: April 29, 2013 at 1:14 AM / IP Logged
You look for power at the switch then if it's there test the switch, motor wires etc.
If no power at the switch, work backwards.
