timed relay regardless of trigger
voltagexdt
Member - Posts: 18
Posted: April 26, 2014 at 11:06 PM / IP Logged
im beat so let me see if I can explain this.
I need a relay that will turn on when triggered but turn off after 30 seconds regardless if the trigger is still on.
then when the trigger is cut, and re-engaged the process starts over.
Posted: April 27, 2014 at 2:32 AM / IP Logged
DEI 528t, 611 PAC 250(?).
voltagexdt
Member - Posts: 18
Posted: April 27, 2014 at 11:14 AM / IP Logged
I did do research on the dei concern was it says pulsed out. typo? as I need steady
Posted: April 27, 2014 at 11:53 AM / IP Logged
All above but definitely the 528t are PULSED in, timed out.
