Posted: December 10, 2014 at 8:14 PM / IP Logged
Posted: December 10, 2014 at 8:57 PM / IP Logged
Posted: December 11, 2014 at 12:33 AM / IP Logged
Posted: December 11, 2014 at 8:49 AM / IP Logged
Posted: December 11, 2014 at 10:10 AM / IP Logged
Posted: December 11, 2014 at 10:39 AM / IP Logged
Posted: December 11, 2014 at 10:50 AM / IP Logged
Posted: December 11, 2014 at 3:51 PM / IP Logged
Posted: December 11, 2014 at 4:02 PM / IP Logged
Posted: December 11, 2014 at 7:14 PM / IP Logged
Thursday, May 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Hopefully that picture is attached correctly!
Just wanted to first say thanks for all the wealth of information here, it is greatly appreciated.
So I have a original 1927 model T roadster with a hemi. I got the whole car wired up and fired up. Only problem was I was using a 2 wire 1157 bulb and socket. I had turn signals and brake lights, but wanted park lights on the dim filament and the turn and brake on the bright.
When I had everything working before, the power for blinkers came out of the fuse block, which has a built in flasher. That went straight to a toggle switch, on off on. From there I ran wires to front and rear for signals and all worked fine.
I went by this diagram here so I could add the turn and brake on the bright filament, park on the dim, and grounded socket to the frame.
Everything works perfect and I followed your schematic exactly. Only thing is when I apply the brakes, I get no turn signals. I let off on the brake and the signals come back on.
What am I doing wrong here? I suspect I might need to change something in the wiring of the relays. I just don't know where to start?
I appreciate the help and hope that wasn't too long winded!
Thank you
Bryan
