Need Wire size for relays
gksportster
Posted: April 08, 2015 at 11:47 PM / IP Logged Link to Post Post Reply Quote gksportster
Hello I have some questions about wire sizes for relays one will be for a
electric fuel pump?
Electric door popers?
Electric windows?
Need gage size for jumpers and for the feed and to the electric components ..
Thank you sorry for all the questions just want to make sure I'm doing things right the first time . Kelly
Posted: April 09, 2015 at 3:36 AM / IP Logged Link to Post Post Reply Quote howie ll
Windows, allow 25 amps per pair.
Poppers, 10-15 amps each.
Fuel pump 10-15.
These sizes should also be on the instructions.
Then, Google wire gauges, that will give you the current capabilities.
gksportster
Posted: April 09, 2015 at 11:15 PM / IP Logged Link to Post Post Reply Quote gksportster
Thank you . I pulled the electric windows out of a 96 Toyota corola
The shaved door kit is from autoloc 35 to 50 lbs pull
Fuel pump is a Holley
I was told that 12 gauge wire for the shaved door kit
The electric windows in the Toyota looks like 12 gauge also
Thanks again kelly.
Posted: April 10, 2015 at 2:27 AM / IP Logged Link to Post Post Reply Quote howie ll
Hope it helped, I asked you to Google because naturally the rest of the world doesn't use US wire gauges and I couldn't do the conversion in my head!!
