Cooling Fan Relay
timkins
Member - Posts: 37
Posted: June 11, 2017 at 5:48 PM / IP Logged Link to Post Post Reply Quote timkins
I have an electric fan on my radiator that is switched by a relay. Today I melted a 30 amp fuse and the wire leading from the relay to the starter. I am a complete dummy when it come to the electrical and relays. The relay I am using is a 5 post relay with 86 going to the fuse panel. Post 85 goes to the starter with a 30 amp fuse in line,post 87a goes forward to the fan (I think) along with the post marked 30. I think the post marked 87 goes to ground I AM NOT sure. If someone has a diagram where all this goes I would appreciate it. If I wanted a manual switch where would it go along with an indicator light telling me the fan is on.
the12volt
Administrator - Posts: 3,959
Posted: June 12, 2017 at 8:40 AM / IP Logged Link to Post Post Reply Quote the12volt
Connect as follows to have the fan come on when the ignition is on or when your switch is on:
85 to ignition 12V+ or switch
86 to ground
87 to fused 12V+
30 to fan positive
87a not connected to anything
Fan negative to ground
Cooling Fan Relay -- posted image. the12volt • Support the12volt.com
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
