If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Hopefully this explains the two circuits best. I do not know if a relay is the right piece of hardware in order to connect the two circuits but if there is another component that would make this work the way I wish, please let me know.
If the answer is 'Yes' to my question, the relay coil (85&86) isn't being energized - you would need to connect 85 to +12V instead of ground.
When you manually power up the dome lights - are you connecting a ground wire to the terminal that is connected to 30 on the relay?
