Turn Signal to Constant Output for LEDs
cumminstech
Posted: May 13, 2019 at 6:52 AM / IP Logged Link to Post Post Reply Quote cumminstech
I am building headlights for my 98.5 Dodge Ram 2500. I am trying to use sequential turn signals in the front which require a constant 12v. I have reviewed the pulsed to constant output diagram but am in need of some clarification as to what size diode, capacitor and resistor I will need. How long will the specified diode keep the relay closed?
Platinum - Posts: 13,726
Posted: May 13, 2019 at 5:33 PM / IP Logged Link to Post Post Reply Quote i am an idiot
A bigger capacitor will keep it engaged longer. That diagram as it sits will be a constant output as long as the blinker is sending it's usual pulses.
cumminstech
Posted: May 13, 2019 at 8:46 PM / IP Logged Link to Post Post Reply Quote cumminstech
Ok cool. That’s what I was looking for. Does the type of diode matter? I’m pretty new to more in depth vehicle wiring
geepherder
Platinum - Posts: 3,668
Posted: May 14, 2019 at 7:50 PM / IP Logged Link to Post Post Reply Quote geepherder
A one amp switching/rectifying diode will be fine.
cumminstech
Posted: May 24, 2019 at 9:23 PM / IP Logged Link to Post Post Reply Quote cumminstech
Got the diode and built my circuit. The diode discharges almost instantly and does not hold the relay closed at all. I am using a typical automotive relay. How big of a capacitor do I need to hold it closed for a second or two? Can I add multiple capacitors together to make the micorfarads I need?
eguru
Copper - Posts: 340
Posted: May 24, 2019 at 9:48 PM / IP Logged Link to Post Post Reply Quote eguru
You only need to keep the relay energized for about half a second. Make sure the diode is oriented correctly. You can parallel more capacitors if necessary.
Also a higher resistance coil in a smaller relay may be appropriate - perhaps your relay is larger than required.
Posted: May 25, 2019 at 8:55 AM / IP Logged Link to Post Post Reply Quote i am an idiot
What size capacitor did you use? The diagram calls for 10,000 microfarads. Yes you can parallel capacitors to achieve 10,000
cumminstech
Posted: May 27, 2019 at 10:11 AM / IP Logged Link to Post Post Reply Quote cumminstech
Turns out if you have install a 10 microfarad capacitor instead of a 10k microfarad capacitor it won’t work correctly. Thanks for all the help guys. You have been a huge help👍🏻
