Constant To Momentary Relay
accordcu2
Member - Posts: 7
Posted: May 21, 2023 at 9:44 AM / IP Logged Link to Post Post Reply Quote accordcu2
Hi,
Just wanted to better understand this relay.
Will this relay only give 12v momentary output once its de-energised?
https://www.the12volt.com/relays/relaydiagram45.html
Honda Accord
cpalmer
Copper - Posts: 115
Posted: May 21, 2023 at 11:35 AM / IP Logged Link to Post Post Reply Quote cpalmer
It gives a 1/2 second pulse when negative is applied to the "switch" part of the diagram.
accordcu2
Member - Posts: 7
Posted: June 05, 2023 at 8:33 AM / IP Logged Link to Post Post Reply Quote accordcu2
Hi, sorry just a stupid question. So whenever negative is applied, it will give short negative output? If the applied negative is constant then it will still give short negative output? Doesn't matter how long the applied negative is?
Honda Accord
