4 or 5 wire relays?
Da Flash
Member - Posts: 11
Posted: April 20, 2004 at 6:53 PM / IP Logged
I'm installing a Crimestopper (cs2001fc) alarm and have a few questions when it comes to the relay for the starter kill. When I look at the diagram that it has the following configuration;
86. to alarm brain
85. ignition "on and/or start"
87a. to the starter ("cut starter wire and connect between 87a and 30 on relay")
87. it doesn't show any use for this.
30. Not quite sure where this wire is supposed to come from but.......
Now the questions;
I've gotten 2-12VDC relays, 1 from Rat Shack, and 1 from an installation shop. Both have 4 spades on them labeled 87, 86, 85, and 30 ( there's a 87a in the middle but there's no spade for it) While looking on partsexpress's web page I noticed that their relays/plugs have 5 spades!
Does it matter if the relay has 4 or 5 spades??
Since the diagram shows I need to connect something to 87a, does this mean that I've got the wrong relays??
toddrgudde
Member - Posts: 6
Posted: April 20, 2004 at 7:10 PM / IP Logged
wat sup realys can be confusing cant they when i furst startes 5yrs ago they baffled me once you lean them you will be amased wat you can do with them hers a link insted of tring to tell you  www.the12volt.com/relays/page2.asp
Da Flash
Member - Posts: 11
Posted: April 20, 2004 at 7:21 PM / IP Logged
Thanks that is pretty informative but, it doesn't tell me the difference between "normally opened" and "normally closed" Also what is the difference between 4 and 5 spade relays?
toddrgudde
Member - Posts: 6
Posted: April 20, 2004 at 7:29 PM / IP Logged
ok yes you need a different realy with 87aok  87a and 30 are connect togther when the realy is not powered up but  when the alarm goes off it sends ground throught the orange wire and when you try to start the car it energizes the  realy cause 87 AND 30 to connect  thus  you have a no start  normaly open means that the circut is broke normaly closed means the circuit is connected sorry any othere questions ask thans todd
Da Flash
Member - Posts: 11
Posted: April 20, 2004 at 8:26 PM / IP Logged
Hey Todd sorry if I was coming at you with a 'tude nothing meant by that, and you have broken down the lingo so that even I can understand4 or 5 wire relays? -- posted image. Now all I have to do is put in an order to partsexpress ( I can't find the 5 spades anywhere4 or 5 wire relays? -- posted image.)
Thanks!!
toddrgudde
Member - Posts: 6
Posted: April 20, 2004 at 8:33 PM / IP Logged
go to your local stereo shopp hey it ok it frustating hell go to a junk yard walk around look thats were i get mine i have since retired from the biz i do it on the the side i work in late model auto salvage now it pays more todd
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
