what kind of relay do I need?
casnj
Member - Posts: 17
Posted: June 07, 2004 at 12:06 PM / IP Logged
what kind of relay do I need for this and how do I wire it?
i have two wires one that goes positive and the other is 0 when the door is locked.  then they both go to positive at unlock.  well if the 1st condition exist I want the positive voltage to flow to my device.
markcars
Silver - Posts: 662
Posted: June 07, 2004 at 3:54 PM / IP Logged
I don't know what exactly you're wanting but I you can accomplish any switching requirement with a spdt relay. If there is 2 simultaneous switching that you need the go for a dpdt relay or 2 spsts will do too.
casnj
Member - Posts: 17
Posted: June 07, 2004 at 5:23 PM / IP Logged
what i want to do is simple.  im just not explaining it fully :)
i have two wires.
    one is positive and one is negative during lock
   both are positive during lock
when the 1st condition exist I want the power to go to a pin
when the 2nd condition exist i want te power to go to another pin
I need the 1st condition.  the 2nd is optional
CHaseHeadrick
Member - Posts: 34
Posted: June 08, 2004 at 10:51 PM / IP Logged
i don't understand how they can both be positive during lock, or at unlock? if they rest a ground, then when one wire changes to 12v+ it is the function (lock/unlock) wire. if they rest at 12+, then its the same way, the wire that stays at 12v+ is the function wire.
93 4RUnner
Alpine H/U
Alpine Mids/Highs
Alpine Security w/DEI remote
start and window control
Rockford Lows.
markcars
Silver - Posts: 662
Posted: June 09, 2004 at 4:49 PM / IP Logged
You could use a single pole double throw relay(SPDT) available at any electronics stores. Even Radio Shack has them if you don't have it already.
Connect pin 85 to ground (-ve)
        pin 86 to the wire that gives +ve at lock
        pin 30 to a constant +ve
        pin 87a to the wire that you want power during lock
        pin 87 to the wire you want power during unlock
casnj
Member - Posts: 17
Posted: June 10, 2004 at 7:56 AM / IP Logged
so pin 85 is connected to the wire that shows ground when locking right?  pin 85 is not a chasis ground?
casnj
Member - Posts: 17
markcars
Silver - Posts: 662
Posted: June 10, 2004 at 4:10 PM / IP Logged
Pin 85 goes to direct chassis ground.
markcars
Silver - Posts: 662
Posted: June 10, 2004 at 4:18 PM / IP Logged
casnj wrote:
also will this relay work
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F011%5F002%5F013%5F000&product%5fid=275%2D240
This won't work, and if it does it will burn out! Get yourself a BOSCH automotive relay or a similar one. They're for autos and can handle the high amperage if you need it, plus they get energized by 12v. The one on this link is a 5 Volt so I'd say don't get this.
At the Shack, the part number is
30A Automotive Relay
Catalog # 275-226
If you just walk by to a Radio Shack nearby where you live, you can just pick one up from their parts section. They're in a tray marked "Automotive Relays" or "Relays"
casnj
Member - Posts: 17
Posted: June 10, 2004 at 6:49 PM / IP Logged
this wont work then.
wire 1 is positive at lock and wire 2 is negative
wire 1 is positive at unlock and wire 2 is positive
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
