relay to isolate starter
briandors
Member - Posts: 45
Posted: October 19, 2004 at 4:29 PM / IP Logged
I need to isolate the starter wires during remote start.  Can someone explain to me which terminals to connect where?  This is a car that has two starter wires (one is for cold start).  Do I use one relay or two?
chrane
Member - Posts: 27
Posted: October 19, 2004 at 11:46 PM / IP Logged
manual or automatic transmition, and which kind of car?
Aaron
briandors
Member - Posts: 45
Posted: October 20, 2004 at 6:35 AM / IP Logged
96 Altima.
If I don't isolate either starter wire, car remote starts and idles well, but turning the key even just to ignition causes starter grind.
If I isolate only main start wire, still grind.
If I isolate both (through one relay, or two), no good.
If I isolate just the cold start wire, everything works, but I think the car is idling too low when remote started.
Brian
briandors
Member - Posts: 45
Posted: October 20, 2004 at 6:36 AM / IP Logged
Oh, automatic transmission.
