Trunk release help
Vietboy19
Posted: December 31, 2004 at 3:09 AM / IP Logged
Hi i have a 2002 honda accord. it's already have power trunk release, the wire is Negative. i just bought a remote starter  for it. The truck release wire from the remote starter is Negative to, so Do i support to use a relay in order to pop the trunk. if i need a relay for it, how can i tie it up? please help , thanks
Johnny Nguyen
johnnydi77
Copper - Posts: 54
Posted: December 31, 2004 at 7:18 AM / IP Logged
Just put the wire from the remote start to the neg trunk release wire. the only time you would have to use a relay in this situation is if the trunk release was positive, reverse polarity, or required a high current ground.
John J. DiStefano Jr.
Vietboy19
Posted: December 31, 2004 at 8:10 PM / IP Logged
i did try to do that, but it doesn't work.
Johnny Nguyen
johnnydi77
Copper - Posts: 54
Posted: January 01, 2005 at 1:01 PM / IP Logged
trunk release on that vehicle is WHITE/ red positive in the drivers kick. you will need to build a relay
Vietboy19
Posted: January 01, 2005 at 7:12 PM / IP Logged
Can you tell me how to relay it? please Johnnydi77
Johnny Nguyen
Jschult3
Copper - Posts: 106
Posted: January 15, 2005 at 2:26 PM / IP Logged
Pin 85 = +12 volts
pin 86= - 200ma from alarm
pin 87= Ground
Pin 30= Trunk wire(RED / White in your case)
Pin 87a=unused
Pin 86 turns relay on and connects 87, ground, to 30 trunk wire as long as 86 is sending the -200ma's. I've always wired  a relay for the trunk pop. it helps protect the alarm, seeing how most are only 20ma's which is just enough to power the SPDT relay you'll be using. I'll bet if you pull the "button" on the car you'll see 1 side is grounded to the frame and the other is a RED / White wire.
Good Luck,
Always Verify Wire information before Connecting! Just a Darn Good DIY'R
