Loss of sound Quality?
ravenndude
Silver - Posts: 250
Posted: February 23, 2005 at 4:22 PM / IP Logged
Using this this Diagram:
Loss of sound Quality? -- posted image.
Will it cause a loss of sound quality?
I was going to make two different boxes for a brahma (hopefully one of the new ones if it comes out before summer and is under $450). One for daily driving (a small sealed box and sub wired at 4 ohms) and one for comp (decent sized ported box and sub wired at 1 ohm). But instead I can make one medium sized sealed box with this switch somewhere. THat way all i have to do is hit a switch to get into "comp mode" or is I jsut want to show off at a car meet or around friends.
kfr01
Gold - Posts: 2,121
Posted: February 23, 2005 at 4:43 PM / IP Logged
This is a great idea for those who want both competition ready setups and sq for daily driving.  I'll bump this because I'm curious.  :-)
New Project: 2003 Pathfinder
DYohn
Platinum - Posts: 10,741
Posted: February 23, 2005 at 5:09 PM / IP Logged
I'd say as long as the relays were good quality components that can handle the voltage and current from the amp it should be fine.  I'd sugegst measuring the closed contact resistance through them in both the normal and the activated positions and use relays with less than a tenth of an ohm.  Also, I highly recomend you rig it so that it could never be switched under load.
ravenndude
Silver - Posts: 250
Posted: February 23, 2005 at 6:03 PM / IP Logged
where can i find such high quality relays? parts express? I guess it would have to handle 1500 watts (that's how much the amp puts out at 1ohm RMS)
And do you know how that diagram works exactly?
I guess I have ground --> switch --> purple(or pink) wire in diagram
is it mono when the switch is on or off.
I'd be using one of those military on/off switches
uthinkuknoaudio
Silver - Posts: 760
Posted: February 23, 2005 at 8:30 PM / IP Logged
i'm very interested. (bump)
"I don't play games. I play Nakamichi and that for real yo" - Probably some japanese kid said this in the early 80's trying to sell stereo out of his trunk lol.
ravenndude
Silver - Posts: 250
Posted: February 24, 2005 at 9:46 AM / IP Logged
Can a Mod move this to the Relay forum? I forgot about that one and this might get a little more attention there.
-Thx
ravenndude
Silver - Posts: 250
Posted: February 25, 2005 at 12:16 AM / IP Logged
Bump?
ituneyou
Member - Posts: 40
Posted: February 25, 2005 at 12:43 AM / IP Logged
That diagram looks like a great idea, but i would not use it on my own amp , its kinda scary to see 12v+ anywhere near the outputs of the amp, if one of those relays ever go bad it could feedback 12 volts straight into the outputs of the amp.
good luck
        steve
A man has got to know his limitations
ravenndude
Silver - Posts: 250
Posted: February 26, 2005 at 1:34 PM / IP Logged
could i put in a diode in for safty reasons then? They would be placed on the "amplifier out (one hcannel) in that diagram
