Relay for dummy!!
Cooter
Posted: November 13, 2002 at 4:27 PM / IP Logged
Ok so I used to install remote starts, and alarms professinally some years ago. I would like to start doing it again. I just would like a littl einsight, a diagram would be great if available.  basic relay uses are:
NEG. To Pos.
Pos. to Neg.
Low volt. To High Volt.
High volt to low volt.
If someone has so diagrams to explain what pins connect to where, I would very much like to have them.              THANKS
djfearny2
Silver - Posts: 810
Posted: November 13, 2002 at 4:36 PM / IP Logged
HIGH VOLT TO LOW VOLT NOT happening.,
neg to pos
pin 86and87 pos 12
pin 30 output
pin 85 negative trigger.
basically whatever you want to come out of pin 30 you need to put into pin 87  and use a pos and negative through pin 85and 86 to activate it .
low volt to high volt is
pin 87 pos 12
pin 85 ground pin 86 pos trigger 97a not used and pin 30 is your output.
pos to neg is
negative on both 86and 87 87a not used , pos 12 signal to pin 85 and 30 is output.
Jon
Installer/Help Technician
---coral springs florida---
Cooter
Posted: November 13, 2002 at 4:40 PM / IP Logged
So djfearny yo say That it sno possible to change a high voltage pulse into a lower voltage pulse?
Platinum - Posts: 12,488
Posted: November 14, 2002 at 5:38 AM / IP Logged
Here is some visual help with the relays: http://www.velocitymotorsport.com/install_notes/install_main.htm go to "  CONVERTING POLARITY "
securinu
Silver - Posts: 772
Posted: November 14, 2002 at 6:09 PM / IP Logged
high volts to low would use a resistor.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
