need relay help fast!!!
SlamThem
Posted: November 21, 2002 at 5:18 PM / IP Logged
well i'm still tryin to hook up my alarm but still have trouble trying to make it work with my alarm.. the doors aren't working once i put them to the relay and i hook everything up!!i'm just wondering if i got the right relay i bought them from canadian tire. they are 12v relay do i need to get a certain kind to make everything work. also when i hook everything up should there be any wires that become positive after i hook everything up!!!i have a 1992 jimmy and the wires are negative when i put the test light to them but as soon as i hook them up to the relays two or one of the wires becomes positive what am i doing wrong.
I want my car way below you!!!
Chris Luongo
Platinum - Posts: 3,746
Posted: November 21, 2002 at 5:49 PM / IP Logged
Try to type your stuff a little more clearly--my head is spinning now.  Anyway, we'll need a lot more information to help.
What kind of Jimmy is it?  K5 or S-15?  If S-15, four-door or two-door?
I have no idea what kind of relays Canadian Tire sells.  Doesn't the package say what type of relay it is?
What type of system are you trying to wire up?  Is this a 5-wire (reversing polarity) car?
 What color are the wires you're interfacing to?  About how thick are they?
You said the car's wires test as negative..... WHEN do they test as negative?  When the locks are at rest, or when you're pushing the button?
Where have you connected each pin of each relay?
Player69
Silver - Posts: 504
Posted: November 21, 2002 at 6:50 PM / IP Logged
Platinum - Posts: 12,488
Posted: November 22, 2002 at 12:45 AM / IP Logged
You need a 5 pin 30/40 amp relay. SPDT
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
