SCR? solid state relays
03sdccfx4
Member - Posts: 24
Posted: June 10, 2005 at 8:11 PM / IP Logged
I need to have a device that will make the turn signals, and marker lights on a trailer a seperate circuit from the truck.  I would like to do this without using mechanical relays.
I am needing to use something solid state, I believe SCR's would be the correct application for this
Could anybody send me a schematic or at least provide me with some part numbers?  I think a 20amp or better RMS rating will do
'03 F-250 CC Fx4
christophe
Member - Posts: 34
Posted: June 11, 2005 at 9:12 AM / IP Logged
even easier a company called hoppy actually makes the product. you can find this at any trailer supply company. good luck
hotwaterwizard
Silver - Posts: 1,350
Posted: June 11, 2005 at 11:49 PM / IP Logged
SCR's will Latch with DC.
Transistors Could Do the job
Exactly what are you trying to do?
But how would you Charge the Battery on the Trailer?
Trailer Isolator
http://www.vpaccessories.com/Trailwr.jpg
http://www.kriss.com/signalcontroller.htm
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
03sdccfx4
Member - Posts: 24
Posted: June 13, 2005 at 12:13 AM / IP Logged
The battery will be on trucks still I just need higher capacity circuits to run all the lights on the trailer(s).  I could do it with relays but, solid state would be nicer.
Left Turn/Brake
Right Turn/Brake
Marker Lights
I will use the truck feed for these lights to trigger what ever it is I will use.
'03 F-250 CC Fx4
hotwaterwizard
Posted: June 13, 2005 at 11:31 PM / IP Logged
SCR?  solid state relays -- posted image.
Stockton California
hotwaterwizard
Posted: June 14, 2005 at 12:07 AM / IP Logged
Stockton California
03sdccfx4
Member - Posts: 24
Posted: June 14, 2005 at 2:49 AM / IP Logged
I am slightly confused on the diagrams where does the load connect?
I will be feeding whatever I use with a fused 20-30 amp circuit.  Then the unit will feed the trailer plug in.  The truck wires will be used for the trigger.
I don't see where the higher current would come into play here?
'03 F-250 CC Fx4
03sdccfx4
Member - Posts: 24
Posted: June 14, 2005 at 3:00 AM / IP Logged
Ok thought about it some more, I need a circuit that will switch the positive with a positive trigger.
I am thinking it will take two transistors to do this right?
I think I need to use a positive switch for the load with a smaller transistor as a negative switch to get my positive trigger changed to a negative trigger.
Am I on the right road here?
'03 F-250 CC Fx4
hotwaterwizard
Posted: June 14, 2005 at 10:00 PM / IP Logged
Yes you are on the right track.
And the Light Bulb is the Load
Stockton California
03sdccfx4
Member - Posts: 24
Posted: June 14, 2005 at 10:06 PM / IP Logged
What would be a suitable smaller transistor to use for the trigger, since it will not have the current flow the load will.
'03 F-250 CC Fx4
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
