How do I know which relay diagram to use?
glickchic
Member - Posts: 7
Posted: November 22, 2002 at 1:10 PM / IP Logged
I have a 1999 Chrysler Town and Country AWD.  I am trying to hook up a commando keyless entry remote to the existing keyless entry.
Are the wires that I am connecting it to under the dash/kickspace or, in the door???
Help Me
Jeanne
securinu
Silver - Posts: 772
Posted: November 22, 2002 at 1:33 PM / IP Logged
they are in the driver kickpanel.  on the bcm there are 3 relays on the bottom left pull all 3 and tap pin 30 for a positve output to control your alarm.
glickchic
Member - Posts: 7
Posted: November 22, 2002 at 1:59 PM / IP Logged
This is all new to me.  What is bcm? what does pull and tap pin 30 mean?
Platinum - Posts: 12,488
Posted: November 22, 2002 at 2:07 PM / IP Logged
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|blue                |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ orange        |+  |ignition harness            |
|        ACCESSORY|BLACK/ white *1      |+  |ignition harness            |
|       POWER LOCK|WHITE/ green         |*2 |left plug at bottom of fuse |
|     POWER UNLOCK|same wire           |*2 |box under cover (1 of 3)    |
|       LOCK MOTOR|brown               |   |*3                          |
|     UNLOCK MOTOR|BLACK/ pink          |   |*3                          |
|    DISARM DEFEAT|violet/white        |   |*3                          |
| PARKING LIGHTS +|do NOT use          |   |                            |
| PARKING LIGHTS -|grn/wht or grn/red  |   |at light switch *4          |
|       HEADLIGHTS|lt. GREEN/ orange    |-  |at light switch             |
|     DOOR TRIGGER|BROWN / lt. green *5  |-  |dome light on/off sw.       |
|  TRUNK/HATCH PIN|tied in with doors  |   |                            |
|         HOOD PIN|pink/black          |-  |underhood light             |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|see directfax #1081 |   |                            |
|       TACHOMETER|gray or gray/red    |   |ignition coil               |
|       BRAKE WIRE|WHITE/ tan           |+  |brake switch                |
|     HORN TRIGGER|gray/orange         |-  |top right plug of fuse box  |
|           WIPERS|pink/purple         |-  |steering column             |
|  LF WINDOW UP/DN|lt. green - white   |A  |drivers door switch         |
|  RF WINDOW UP/DN|brown - purple      |A  |drivers kick panel          |
|  LR WINDOW UP/DN|dk. blue - red      |A  |drivers kick panel          |
|  RR WINDOW UP/DN|gray - dk. green    |A  |drivers kick panel          |
Notes:
*1 Not required for remote start.  *2 Use relays and set up for negative trigger.  Place a 4020 ohm resistor inline on the lock output, and a 665 ohm resistor inline on the unlock output.  If you don't have a factory security system use a 1500 ohm for lock and a 250 ohm for unlock.   *3 The door lock motor wires are located in the top left plug at the relay/fuse box under the drivers side of the dash.   *4 If the van has "auto lamps", see direct fax document # 1080  *5 For dome light supervision, use BROWN / white at the dome light on/off switch on the dash.
glickchic
Member - Posts: 7
Posted: November 22, 2002 at 2:13 PM / IP Logged
o.k.  does this mean tap means that I need a resistor?
Posted: November 22, 2002 at 2:19 PM / IP Logged
Yup ..... you will need two relays and proper resistor values to do the lock/unlock. Go here ( http://www.velocitymotorsport.com/install_notes/Converting_Outputs.jpg ) and use the " negative input---->negative output diagram with the proper resistor inline of pin 30. If you do not use a relay, you may run the risk that the RS unit that you have not supplying the unlock/lock wires with a solid enough ground. That means having to take everything down and doing it properly , with relays.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
