Diagram for horn beep on door lock
petie-tl
Member - Posts: 8
Posted: July 23, 2005 at 5:42 PM / IP Logged
I have a 98 Acura TL 3.2 with factory alarm which doesn't do anything when the doors are locked by remote except for locking the doors. I want to add a horn beep and light flash for when the lock button is pressed. Here is the diagram I came up with, but I have a few questions (included in the diagram). Thanks for any help you can give me.
Diagram for horn beep on door lock -- posted image.
Thanks!!
petie
'98 Acura TL 3.2
alpine0000
Copper - Posts: 160
Posted: July 24, 2005 at 11:07 PM / IP Logged
Thanks!!
you can tap into the 12v at your ignition since this relay will most likely be under your steering column somewhere
you can ground the relay by using a ring terminal and screwing into metal in the kick panel
parking lights diode #1
horn diode #2
fst100
Copper - Posts: 60
Posted: September 29, 2005 at 7:42 AM / IP Logged
seems like you have the same idea as i do, except i have a 99 chevy cavalier.  alpine0000 when you say
horn diode #2
what do u mean in regards to the diode? is it to be pointed in a specific direction for the current to run/stop?
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
