charging system relay wiring for Dodge
daytona88
Posted: November 15, 2005 at 6:46 PM / IP Logged
I recently convert from injectors to carburated on my Daytona 1988TBI/EFI.
The computer was removed and all sensors are been exchangeg for older reliable reading sytem senders, like voltage,fuel,tach and speed gauges. I want to use the curent alternator, a 40/90 amp BOSCH . I allready have ID the terminals use and located the starter connectors as well. I need someone to help me with the RELAY controling the charging/starting system. I know a relay is use but i want to use the best one and not as expensive as the originals. I have a % poin BOISCH RElay , prewired and is ready to install. My problem is "HOW". I have some details on the wiring and the schematic shows the relay, but is of no use since this car was pre owned and the other owner rewired the system. I can tell because while working on it I found 3 different wiring plugs and connectors. So i decided to make it my project car. Is a solid car and I feel safe in it. I have it starting but after starting the relay is suppose to change from battery to alternator. I have a TOYOTA 3 wires alternator. One cable for ground, one for battery and oher for warning light, just in case i get tire trying!.As i mentioned, i am a knowledge freak and want to know everything on auto wiring. Have some tech information, as well as knowledge in electronics. It sounds funny but it seems that i allready know how but I can't remember and i want to do it right. Please e mail me to papun5880pr@aol.com with sugestions and or drawings.Taking out my metter and tools tomorow to read curent flow and relay functions. I bet I can do it, with your help. Thanks
The more you know, the more you can help!.Sharing is the way to Peace!
Hommo Sappiens Caribbensis
3rd BluePlanet
Ecuatorian Providences
Solar System
daytona88
Posted: November 22, 2005 at 12:19 AM / IP Logged
charging system relay wiring for Dodge -- posted image. Common guys!, all i need is to wire the alternator and the starter to a relay to let CURRENT pass to starter and SWITCH from SARTER(battery) to CHARGE. I really need your help here. the car stars like a kitten and everything eslse works, except the A/C compresor. I know this one!. I think!!charging system relay wiring for Dodge -- posted image.
3rd BluePlanet
Solar System
