Second ignition relay
jdcustoms
Posted: December 23, 2005 at 6:34 AM / IP Logged
What is the best way to hook up a second ignition, using a relay from a viper alarm i also have a second ignition but they supply a wire for that.
Safe & Sound Mobile Electronic Instalation Shop
mobile1
Silver - Posts: 479
Posted: December 23, 2005 at 5:16 PM / IP Logged
try re wording this post. from what i read, you need a second ignition, but you have a second ignition output so just use that.
jdcustoms
Posted: December 28, 2005 at 9:04 PM / IP Logged
Sorry. What i ment tosay was, i have a secong ignition wire and a second accessory wire. They supply one extra wire to do either or so i wanted to use it as a second accesory. So my question is how do i use a relay to make one ignition wire turn into two?
geepherder
Platinum - Posts: 3,668
Posted: December 28, 2005 at 10:44 PM / IP Logged
Wire the ignition output to 86, ground 85, connect 30 to power, and 87 to your second ignition.
