Time Delays
Overcranked23
Copper - Posts: 67
Posted: May 16, 2006 at 3:58 PM / IP Logged
I am wondering how you could set up a circuit to time delay. What I want to do is have aset of lights (led in the head lights that run on B+ (while the truck is running but I want them to stay on a while after I shut the vechile down. Any Ideas. I know that they make time delay realays but I have not found any that fit my application. I would like some choices here so the more ideas you have the better off I would be. adjustable time frames would be nice too
don't fowl the track
hotwaterwizard
Silver - Posts: 1,350
Posted: May 16, 2006 at 8:20 PM / IP Logged
how long do you want them to stay on?
12v LED's or standard 2 volt
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
Overcranked23
Copper - Posts: 67
Posted: May 17, 2006 at 3:02 PM / IP Logged
adjustable would be nice a couple minutes max I guess. I not sure what you mean by voltage I thiught that standard voltage was around 3.3
hotwaterwizard
Posted: May 17, 2006 at 10:39 PM / IP Logged
OKAY
How about this?
You could substitute a 1 meg pot for R
Time Delays -- posted image.
Stockton California
hotwaterwizard
Posted: May 17, 2006 at 10:47 PM / IP Logged
Oh yea here is the pinout for the LM555  Timer IC
Stockton California
ghost ryder
Posted: May 18, 2006 at 8:43 AM / IP Logged
A Dei 528t relay maybe what you're looking for
Overcranked23
Copper - Posts: 67
Posted: May 18, 2006 at 2:49 PM / IP Logged
I like the Idea of the premade relay anyone have any experience with that relay and could tell me how that they would set this up. I want the lights to be on all the time with ign and when the Ign is turned off I want the lights to stay on for 60-90 seconds.
hotwaterwizard
Posted: May 18, 2006 at 10:05 PM / IP Logged
Time Delays -- posted image.This Timer is 0 to 90 seconds. What happened to 4 or 5 min?
http://www.drdetailshop.com/528T.htm
528T Pulse Timer Relay
This special accessory is an adjustable timer with a built-in 30A relay.  The "pulse" timer can be triggered by a + or - pulse or a change of state (from + to - or vice-versa) on the stripe wire.
This product has many popular uses by installers of mobile electronics, some examples: what do you do with a multi-channel remote when the customer has one car and no truck release?  Add a pulse timer relay.
If you need to disconnect a circuit for a certain amount of time, so that the alarm does not activate, you can use the pulse-timer's normally closed circuit, pulse the stripe wire to disconnect the circuit for up to 90 seconds.
Adjustable timer from 0 - 90 seconds.
Stockton California
hotwaterwizard
Posted: May 18, 2006 at 10:08 PM / IP Logged
Guess what?
It looks like it uses the same circuit I gave you with the 555 timer.
Stockton California
Overcranked23
Copper - Posts: 67
Posted: May 19, 2006 at 2:50 PM / IP Logged
Ok Now I have never tried this kind of setup before so mabye you could give me a little detail about the whole pulse what ecactaly does that consist of? what do I use for a pulse
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
