positive pulse on, positive pulse off
sic_fast
Posted: December 02, 2006 at 10:14 PM / IP Logged
Hello all, I have a switch well it's actually a button that I would like to relay so that when pressed (in & out + pulse)  I will have constant 12V output, and then pulsed again, will turn it off.  It's for a rear defogger on an after market jeep hardtop. It came with a toggle but I want to use the factory switch (button).  I looked at the momentary to constant diagram but I'm not sure that's what I need since it uses a ground trigger.
sic_fast
Posted: December 04, 2006 at 2:32 PM / IP Logged
Okay so now I have the switch to pulse neg. and I followed the diagram (momentary to constant ) now it works but it won't shut off until I diconect it which is I guess how the caption explains it to work, but how do I get it to shut off ? When I power it up for the first time it turns on and illuminates the led but it won't turn off.
hotwaterwizard
Silver - Posts: 1,350
Posted: December 04, 2006 at 9:17 PM / IP Logged
A second Relay with a different Pulse.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
hotwaterwizard
Posted: December 04, 2006 at 9:27 PM / IP Logged
Try This.
positive pulse on, positive pulse off -- posted image.
Stockton California
