do i use a relay for my amp?
ishv
Member - Posts: 12
Posted: February 20, 2007 at 10:54 AM / IP Logged
if i want to controll my amp thru a switch (lil ones from dei remote start) can i hook it up direct or should i use a relay. and how would i wire up the relay?
----ish----
i hate relays!!!!!!!!!!!!!
xinstallerx
Member - Posts: 7
Posted: February 20, 2007 at 11:02 AM / IP Logged
if u want to use a relay take
pin 85 to switch with fused 12 v
pin 86 to ground
pin 87 to 12 v fused
pin 87a empty
pin 30 out to amp
Installers will put it anywhere!
spyderbyte
Member - Posts: 25
Posted: February 27, 2007 at 9:38 PM / IP Logged
Why not just splice a switch into the remote turn on lead?
Spyderbyte
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
