minute timer setup after power removed
sdhonda153
Posted: April 02, 2007 at 10:32 PM / IP Logged
Sorry if this is a repeat, but I looked for a while and couldn't find what I was looking for. A lot of the timing circuits here are just for a matter of a few seconds, and for when power is applied. I am looking for a configeration that will supply power for a certain ammount of time, after the source power has been lost. What I am auctually trying to do is wire a timing circuit up to my radiator fans, so when the ignition is turned off, a relay will kick on and power my fans for about a minute or two, to help with engine cooling after the motor has been shut off. Kind of like a Turbo Timer, but only to run the fans. Any help with this would be greatly appreciated. Thanks
- Steve C
hotwaterwizard
Silver - Posts: 1,350
Posted: April 03, 2007 at 8:15 AM / IP Logged
You could just use a thermostat.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
hotwaterwizard
Posted: April 03, 2007 at 8:47 AM / IP Logged
Type this into google
Radiator fan time-delay relay
http://www.thesaabsite.com/900old/900&79to94faqs.htm#Cooling+Fan+Runs+Continuously+%28make+both+fans+run%29
http://www.thesaabsite.com/images/radfandelrel89.gif
minute timer setup after power removed -- posted image.
http://www.buymopar.com/store/restro.html
2889565 Time delay relay
69 and up most models $10.19
http://www.buymopar.com/store/restro/timer.jpg
Stockton California
