relay for airhorns using hornhonk output.
mrspeaker
Member - Posts: 17
Posted: April 19, 2007 at 3:23 PM / IP Logged
Hi,I want to use airhorns just for the alarm. My alarm has a horn honk output (-) ,so, instead of going to the factory horn I want to go to the air horns,How would I set up the relay?
P.S. I searched on here and only found out how to hook up the relay through the siren and using a flasher but i don't want to do that since theres a horn honk output already in the alarm unit.
Platinum - Posts: 12,488
Posted: April 19, 2007 at 9:40 PM / IP Logged
85 - (-) trigger from the alarm
86 - COnstant power
87 - Either (-) or (+) for the horn wire to activate
30 - To the (-) or (+) horn wire
87a - NOT USED
hotwaterwizard
Silver - Posts: 1,350
Posted: April 20, 2007 at 1:38 AM / IP Logged
Okay Help me understand why you think you need a relay?
The air Horn Solenoid takes very little power. Just as much as the Relay coil does.
A Relay is not needed.
Just hook the red to Hot and the Black to the Alarm circuit.
relay for airhorns using hornhonk output. -- posted image.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
